주요 콘텐츠로 건너뛰기
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
20 질문 전체 보기
Why won’t my system read cartridges
Every time I try and play a cartridge game, it never works I also hear this grinding sound, I have no idea why this is happening, can someone please help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
it makes the grinding when on and sitting on a flat surface?
there are no real moving parts in the console so it seems like the grinding would be coming from the speakers probably.
No, it’s when I put a cartridge in on any surface
댓글 달기
답변 2개
가장 유용한 답변
You can try replacing the cartridge slot. The grinding might be coming from thing on the pins or in the slot itself.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Before replacing the slot, you could try a trick to clean the card reader pins first.
  • get some isopropyl alcohol and thoroughly soak the contact points of any cartridge with a Q-tip.
  • put the cartridge in the slot and insert/eject the cartridge repeatedly for about 3 minutes.
  • try it again and see if that fixed it.
hope this helps!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
John Bitzas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 265
