주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2014년 4월 업데이트에는 참신한 듀얼-코어 i5 및 i7 프로세서와 더불어 배터리 성능을 약간 향상시켰습니다.
20 질문 전체 보기
Device fans turn on and charges, but no display
A friend gave this to me to extract the data on it, but I couldn’t find a reliable way to do that with apple’s proprietary SSD, so I’m trying to fix it now.
The targeted disk mode didn’t work, and I checked some voltages around the board but I didn’t see anything obviously wrong. I accidentally touched the CPU heat sink and it was burn-your-hand-hot, but I don’t know if that’s normal or not.
Is there any way to fix this, or if not, get the data off the SSD? Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Sounds like the logic board has serious issues. You could replace the logic board and transfer the SSD to it.
The other approach is to get the required OWC ENVOY PRO which will allow you to transfer the data over to a new MacBook and still be able to be used as a backup drive.
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
Is that ssd reader known to be reliable? I tried a different one and nothing showed up but I believe it was because the reader itself wasn't good.
@belorianrepair - Who did you use?
Apple uses a custom SSD which requires one designed for it. You can't use any M.2 case as they won't work. I've had a few of these and they all work just fine.
@danj it was similar to this one but sold by amazon
https://www.google.com/aclk?sa=L&ai=DChc...
it is for a macbook ssd
@belorianrepair - What can I say, there's a lot of junk sold that doesn't really work or barely works.
Over the years I needed to get newer versions of the case as Apple altered their design so to have a way to salvage users data I needed to get newer units even from OWC. But thats not OWC's fault its just the nature of a moving target.
@danj noted, I'll try out this case. Thanks!
댓글 달기
답변을 추가하세요
Raffi Belorian 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 101
