주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
How to remove the component above the flash unit
I’m trying to do a complete parts scavenging on an iphone 7. with the help of the ifxit teardown guides and my own digging around, i’ve been able to remove everything but one piece. it’s the part that sits on top of the flash unit. it looks a lot like the wifi antenna on the upper left, but it doesn’t come out as easily and i can’t find an ifixit guide that addresses this part specifically.
after removing the screws, it still feels like it’s attached to the flash, or case, by adhesives, but i don’t want to just force (or finesse with heat) at the risk of breaking something that needs to be disconnected first.
can anyone share their experience with removing this component, and also telling me what this component is/does?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
In the top left where you have removed one of the screws, that metal tab can be lifted then there is a standoff that needs to be removed. Have highlighted the area in blue
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
@tonywilmot
you rock! thank you. never would have figured to look under the metal screw flap.
btw, do you happen to know what this component is that i was finally able to remove?
@beekerc I'm not entirely sure to be honest. In the board schematics it is referred to as 'UAT Tuner Flex'. I would guess it tunes WiFi/Bluetooth/NFC etc for specific regions. I have replaced them in the past for faults with WiFi and NFC so must have various uses.
@tonywilmot
makes sense. it does look a bit like the other wifi antenna.
thanks again for your info
댓글 달기
귀하의 답변을 추가하세요
B C 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 35
