주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 질문 전체 보기
sleep/wake button is loose and wont work, need help!
okay, so I have this ipod 4 and I havent tried to fix anything yet but so far only the sleep/wake button wont work... its loose and it wont work. can someone tell me whats wrong and maybe tell me how to fix it?? youtube and apple havent done me much good... thank you!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Niko,
First off how long have you had it? I would try taking it to Apple regardless. I know several people that took in broken screens etc. that were out of warranty and the Apple store replaced them no problem!
If not you need to carefully disassemble it. In order to fix it you have to take it all the way apart which usually means you will have to replace the front panel assy. Follow the teardown guide here:
iPod Touch 4th Generation Teardown
Step 23 shows the button top right. there are 2 screws holding it in place and secured with blue loctite thread sealant. See if these are loose and get them tight. If they are not you have a different problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
niko1234110 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,322
