주요 콘텐츠로 건너뛰기
Apple은 2015년 3월 9일에 Retina MacBook 2015 모델 A1534를 4월 10일에 출시한다고 발표하였습니다. 새로운 유니바디 구조 및 업데이트 된 트랙 패드, 키보드, 그리고 Retina 화면을 포함합니다.
281 질문 전체 보기
Will replacing my logic board effect the data or usability of my SSD?
Hey everyone. I'm currently backpacking in Mexico and it appears that my logic board just crapped the bed on my mid 2014 MacBook Pro. I have a lot of files and information on it that I desperately want to keep. I know there is a way to extract the contents of the SSD using a storage enclosure but I'm wondering if I replace my logic board, will my data remain unchanged?? I'm considering buying the storage enclosure just in case but would prefer not to since it's extremely difficult to ship things to Mexico. Any information on this would be much appreciated!
Thanks!!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi @sheacameron ,
The data on your SSD should remain intact. The SSD is removable from the laptop on the 2015 models. It is held in place by one screw. Make sure you disconnect the battery first before removing the hard drive!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks so much! It sounds like this might not be the absolute travesty I initially thought it was as long as I don't break anything during the replacement.
댓글 달기
가장 유용한 답변
It *shouldn’t* be an issue. If the actual SSD is still in working order, swapping to a new logic board would retain all your original data. Depending on what operating system that board last had on it, there may be some quirks due to firmware stuff. But realistically it shouldn’t be a huge deal. Especially if you keep it within the same model of MacBook.
Some models there is a little wiggle room to swap around between different years, if you have a mid 2014, the form factor remained largely the same in that time period at least amongst the 13” models or the 15” models (you definitely cannot swap between these two), but you may run into issues with compatibility of all parts if you switch years, especially if you swap forward to a 2015, where the display is definitely not compatible.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Excellent info, thank you. Mine is a Mid 2014 2.6 GHZ with 13" Retina and I plan on ordering the identical logic board from iFixit. I have been told by an Apple Tech that as long as I'm careful with the replacement, I should be able to just swap the logic board and everything will remain intact. Fingers crossed! Also, the SSD is still good. I was able to fire up the computer for about 10 minutes and transfer some files to an external HD before it crashed again (I know, probably very risky) but thankfully it didn't currupt any data on the external drive. Anyways, thanks for the info!!
This sounds like a solid plan on all accounts. Bummer your board died. Let us know how it works out!
댓글 달기
귀하의 답변을 추가하세요
Shea Cameron 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 35
전체 시간: 706
