Need help troubleshooting a battery repair.
I recently did a battery replacement on a Surface Pro 4. The repair itself went off without a hitch, but after I made sure everything powered on and put the screen back on I noticed an issue. When not connected to a charger, the laptop will boot, be fine if it’s not moved, but as soon as it’s bumped, even from an aggressive key press, it will lose power. I think that maybe the battery contacts on the PCB might need to be cleaned, but I would like to hear everyone else’s opinions in case that isn’t the issue. Thanks!
좋은 질문 입니까?
점수
0
Phoenix Knipe it is possible. Just make sure that all the flex cables are properly attached and seated correctly. What a Royal PITA that battery is :-)
oldturkey03 의
