주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
Read SSD data with adapter
Hi,
My Macbook Air (1466/EMC2925) has passed away. I disassembled it and took out the SSD. I thought it would be easy to connect it to an adapter. It turns out that the adapter is pretty expensive (119 euro/140 dollar). I think that’s pretty expensive just for an adapter.
Is there a inexpensive adapter(maybe from Aliexpress) which i can buy? I was aiming for around 20 dollars. Basically it is just a converter to USB/SATA 3,5’’
Kind regards!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
What country are you located in?
댓글 달기
답변 1개
선택된 해법
Apple did their own thing! As such you need to use this custom case External SSD Enclosure for Select Mid 2013 to Mid 2015 Macs or OWC ENVOY PRO
To learn more on Apples custom drives give this a read The Ultimate Guide to Apple’s Proprietary SSDs
I haven’t seen to many other options. There are a few PC cards which allow you to fit the drives into a Windows PC.
Use the SSD originally installed in your Mac as an external drive in this enclosure. USB 3.0 transfer speeds up to 500 MB/s 이미지
제품
$99.99
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Fixxxm8 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 101
