brake lights not working & blinkers sometimes quit working
brake lights not working. lights and fuses good. blinkers stop working some times. emergency flasher work.
좋은 질문 입니까?
좋은 질문 입니까?
@perz for your non-functioning brake light you would start by checking the brake light switch on your brake pedal. Make sure that it is working (of course you checked the bulbs etc.)
The blinkers sometimes not working could be a n issue with corrosion on the ground wire etc. Check that all the wires going to the relay are in good working order as well. The location of the relay is on the right side of the steering column just above the diagnostics port
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 5
30일 전: 8
전체 시간: 50
댓글 3개
Intermittent electrical often means a loose or partially broken wire somewhere.
Aaron K 의
it was the multifunction switch came unplugged.
lossersl 의
multifunction switch game unplugged.
lossersl 의
