주요 콘텐츠로 건너뛰기
2018년 9월 21일 출시. Models A1920, A2097, A2098, A2100. GSM 또는 CDMA / eSIM 또는 nano-SIM / 64, 256, 또는 512GB / 은색, 금색 또는 스페이스 그레이. ("iPhone 10 S"로 발음합니다.)
398 질문 전체 보기
Why is my iPhone XS restarting all the time?
I hope this part of the panic log is enough since I cant post all of it:
"termination" : {"code":2,"flags":6,"namespace":"WATCHDOG","details":["checkin with service: thermalmonitord returned not alive with context:","is_alive_func returned unhealthy : current 6fffffffffffe, mask 37ffffffffdff, expected 37ffffffffdff. SD: 0 BC: 0 Missing sensor(s): TG0B Prs0","no successful checkins since wake (120 seconds ago), 59 seconds since last crashed by watchdogd, (1 induced crashes)"],"reasons":["checkin with service: thermalmonitord returned not alive with context:","is_alive_func returned unhealthy : current 6fffffffffffe, mask 37ffffffffdff, expected 37ffffffffdff. SD: 0 BC: 0 Missing sensor(s): TG0B Prs0","no successful checkins since wake (120 seconds ago), 59 seconds since last crashed by watchdogd, (1 induced crashes)"]},
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
This panic log is giving the error that the phone is not getting check ins from particular sensors: TG0B and PRS0.
TG0B is a battery sensor and PRS0 is the barometer. This could be the result of a few things, but generally it seems to be an issue with the dock flex (the cable assembly the charge port is part of). I would start with replacing that, generally a high quality or OEM part is best. I have heard many people having similar issues with sub-par replacements.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I disconnected the dock and it seems to work! Thank you!
Merhaba bu sorun bende var yaklaşık 4 şarj portu değiştirdim ama sonuç aynı tg0b Var ama prs0 yok lütfen yardım et
댓글 달기
귀하의 답변을 추가하세요
Oguzhan Yilmau 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 204
