주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How do I replace my microSD card slot?
The thing just isn’t retaining my memory card, and I think it’s done for. How do I replace/repair it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 6개
Do you have a hot air station?
nope
i guess i'll just replace the motherboard
i'll need to back it all up
@notnice -96 If you were able to find a replacement microSD card slot, you could use a hot air gun and flux to heat the solder around the microSD card slot, then remove it with tweezers. You would then tin the pads(put solder on rhe pads with a soldering iron) and heat up the board for the new microSD card until it goes into place.
댓글 1개 더보기
댓글 달기
답변 1개
가장 유용한 답변
I think you will just have to use this: Galaxy Tab 3 8.0 Motherboard
It is out of stock right now. This guide should help with that: https://www.ifixit.com/News/56864/findin...
Replace a corroded or malfunctioning main circuit board assembly, including the microSDXC slot, for a Samsung Galaxy Tab 3 8.0. 이미지
제품
$29.99
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
cheers m8, i have another samsung tab 3 that i could cannibalise
i just practiced disassembling it
댓글 달기
답변을 추가하세요
notnice -96 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 49
전체 시간: 554
