주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
Camera not detected after moving computer
Hi everyone,
I typically work at a desk, plugged into an external display. As long as I don’t move the computer, my camera works every time I need it (multiple times a week.)
Every once in a while I’ll unplug and take my laptop elsewhere. Most times that I move, when I go to use my webcam for video calls the camera is not detected until I restart my computer. Restarting works every time.
Has anyone had this problem before? Any ideas on what I can do to fix this?
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
Very odd!
Did you try running the onboard diagnostics to see if that popped an error? Restart your system and press the D key. It might not work as Apple messed up the firmware depending on what macOS you are running.
Reference: Mac startup key combinations
댓글 달기
답변 2개
선택된 답변
I found a solution! Fixed it every time.
Open terminal and type in: sudo killall VDCAssistant
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Does this only happen when moving the entire computer? or just if the display on the laptop gets moved? If it’s only when the screen is being moved it sounds like it could be a short in the cable that connects the camera.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
It's only if I pick up and move the whole machine. I can close the screen and re-open it and it works fine.
댓글 달기
귀하의 답변을 추가하세요
Amber Taus 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 62
