주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
494 질문 전체 보기
Built in display only works fine when connected to an external display
All,
When not connected to an external display. My built in display is erratic its working but the screen is so filled with lines different colors that it is un useable. (although you can see some semblance of the desktop). When I plug in any external monitor with any HDMI cable it starts working perfectly. Both the built in monitor and the external monitor. I have tried so many things Ive ran out and resorted to this forum for perhaps a solution. Things like contacting apple, rebooting, firm ware, Os updates to name a few. I have read countless similar problems But Most of the others are the Built in screen is NOT working in any scenario. While mine does with an external connection. I am now looking at the idea of replacing either part LCD LVDS Display Cable or the HDMI /Usb board. Any thoughts would be appreciated ::
-Sam
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Ouch! In your case the MUX logic within the main logic board is having issues. This is a loading issue where when you connect the external the load needed is present and when you disconnect the external the signals get messed up. Sometimes the issue is within the internal displays T-CON logic.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
Curious, Can the Main board be repaired? (at least this particular issue)and if so recommendations on who where cost?
@thesniper - This is likely repairable, but it will need someone with the deeper skills to fix. Where are you located country and nearest city?
Dan, Currently Im in Vancouver Canada. Use to be in Tampabay!
-S
@thesniper - Sorry I don't know of anyone in that neck of the woods ;-{
댓글 달기
귀하의 답변을 추가하세요
Sam 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 119
