주요 콘텐츠로 건너뛰기
Devices that create three-dimensional objects from digital files through additive processes using various materials such as plastic, metal or resin.
55 질문 전체 보기
ender 5 plus. starts print but then damages pla and clogs.
i have ender 5 plus. it will start print great but after an hour or 2 it damages the pla at the gear and stops feeding pla. how to fix this. i have replaced with aftermarket feeder, new capricorn tube, new nozels and still same issue.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
i have calibrated it
everything i try to print that takes more than 1 hour it acts like it has a clog in the head
the newest 4.11
i have a 10s pro as well and it works fine but this one has been a trouble since i got it.
i have replaced the main board twice and the power supply upgraded once as well as new tubes and 2 nozels. i even thought it might be a moisture issue so i got a dryer for the filament. nothing seems to help
댓글 달기
답변 1개
선택된 해법
Hey Danny,
Have you calibrated your Steps/mm?
What are you trying to print?
What profile are you using for Cura?
(Still new to 3D Printing, but also have an E5P so i’ve been doing a lot of troubleshooting myself)
해당 답변은 도움이 되었습니까?
점수 1
2 댓글:
the newest 4.11
Doesn't sound like a moisture issue.
- What mainboard are you using?
- What are your Steps/mm set to?
- 4.11 Default profile? or have you imported a profile?
- Do you hear any sounds after the hour mark? (Would indicate a clog)
- How close is your nozzle to the bed?
댓글 달기
귀하의 답변을 추가하세요
Danny Thompson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 24
전체 시간: 279
