주요 콘텐츠로 건너뛰기
이 Nintendo DS Lite는 2006년에 Nintendo DS의 후속작으로 출시되었습니다. 이 기기의 내부에 진입하는 방법은 간단하여 손쉽게 수리할 수 있습니다.
Bottom screen of my DS Macro gets too bright after 5min
I have a DS Macro or GBA Macro as you like to call it, the lower screen after being on for more than 10 minutes begins to take on a lot of brightness, I tried to clean the flex cable, readjust it and change the brightness of the screen from the settings but the problem continues . Does anyone know if it is definitely the screen and it has to be changed, or is it something else, I would greatly appreciate the help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @starkiller4k,
This a problem with the back light of your NDS.
It could be either the back light itself, or something related with the luminosity control circuit.
I never had to fix any similar on my NDS so I cannot tell you for sure, but if I were you I would try first replacing the lower screen to see if that solves your issue.
The other option would be to debug the motherboard and check on the screen controller if the line that controls the luminosity of the screen changes with the time. If this happens, then you may conclude that the issue is with the screen luminosity control circuit, rather than with the screen itself.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I think I'll try to use another screen, the problem is that in my region they are just as expensive as a complete DS, I really appreciate it, I just wanted to check if there was any other solution or something that I was overlooking
댓글 달기
답변을 추가하세요
Alan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 204
