주요 콘텐츠로 건너뛰기
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 질문 전체 보기
My pc chrashes every week in between.
Hey. So i have had this pc for around a year and this has been a common issue now. My pc chashes every once a week and when it crashes i need to unplug my graphics card and plug inte in again after around 10 minutes for the pc to work again. And then after a week it does the same. I have checked overheating which shouldnt be an issue. Basically what happens is that the screen goes wide black and everything crashes but the pc still running.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The software or work you are doing on your PC is not capable to handle your card. It is my personal opinion. Might possible your card is old and not enough to work with the latest updates on your software or games whatever you are using. It is also possible that at some point may crash your display because all other time it is working. It should not work any time if there is a card or PC issue.
One thing you cantry simply format your PC and try to check the problem still presists.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Lucas_86 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 49
