주요 콘텐츠로 건너뛰기
MacBook Air 11"의 2014년 4월 업데이트는 새로운 듀얼-코어 i5 및 i7 Haswell 프로세서를 장착하고 배터리 성능을 약간 향상하였습니다.
MacBook Air screen repeatedly malfunctioning
Hello! My MacBook is displaying rainbow pixels, and it is intermittently responding to moving the cursor. When I opened it, it displayed the Lock Screen, then turned all black, with the Apple symbol still lit up. After a few minutes, it switched to nonsensical pixels across the entire screen. After restarting the screen was fine, but this has been happening quite often now, along with the right third turning white, while still working normally. Would anyone know how to fix these screen errors? I have attached a picture of the pixels screen below:
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
Are you able to connect an external display to see if that also shows the colorful static?
If it does then the logic board has issues. If not then you've located the issue is within the display assembly and/or the LVDS cable.
댓글 달기
답변 1개
From what I can tell, the GPU is faulty.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@guardian10 - This system uses the intergraded graphics engine within the CPU chip. Static noise like the display is showing is more likely a bad display or LVDS cable. But without deeper diagnostics its hard to isolate out what needs fixing or replacing.
댓글 달기
답변을 추가하세요
Markus B 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 11
전체 시간: 211
