주요 콘텐츠로 건너뛰기
Mac mini가 오랜 기다림 끝에 새로워졌습니다. 프로세서 옵션에는 3.6 GHz quad-core Intel Core i3, 3.0 GHz 6-core Intel Core i5 및 3.2GHz 6-core Intel Core i7 프로세서가 있습니다.
20 질문 전체 보기
I installed ram today, no power.
Mac Mini 2018 - I installed ram today, no power...double checked everything, no power. Install was smooth, no hiccups, no missed steps signs of stress nor damage. Thinking issue had to be the ram, put the old ram in and the mini now only gives a quick spurt of the fan, then off...rinse and repeat. Can’t image what I did or any damage caused. Anyone else experiencing this? Thoughts?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Update - as many times I checked ram was not properly seated. Everything running smooth now!
댓글 달기
답변 1개
Good morning (From Australia),
Did anything on the motherboard short out and thereby cause something to earth and die?
Did you check all your connections?
Is there anything on the display out
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Good morning!
Process does not run long enough for the display to show signs of life. Fan kicks on high gear for about 5-10 seconds, sits quiet for about 20 seconds. Think the connections are as expected. Took everything apart and back together many times looking for an issue with a connection….and the original and new ram looking for any signs of change.
Short out? Nothing that was obvious and can not see any issues..
Good morning!
댓글 달기
답변을 추가하세요
Pixel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 74
