주요 콘텐츠로 건너뛰기
Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
110 질문 전체 보기
LiDAR sensor not working - is it the sensor or a board problem?
I recently stumbled upon an iPhone 12 Pro Max with an broken LiDAR sensor. The “measure’’ app instantly freezes, and no 3D scanning app detects input from the sensor. All other components in the phone work great and all camera’s work in their normal modes. There also isn’t any excessive power drain or heat generation like sometimes happens with shorts. It also boots normally. I did order a replacement LiDAR sensor, but it will take a while for it to arrive. However, I am currently wondering if it could be related to the power circuit on the mainboard. There’s of course always a chance that it is an board related problem, but how likely is it that it’s an board problem?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 2개
선택된 답변
without some sophisticated test equipment it is a parts jockey fix.
The sensor is the obvious first choice.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
I’ll probably just have to wait until the part arrives to be sure. Luckily it’s dirt cheap at only €15 so I got nothing to lose.
Did you fix it???
Did you fix it???
댓글 달기
It sounds like the sensor is faulty.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Lester 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 24
30일 전: 102
전체 시간: 3,607
