주요 콘텐츠로 건너뛰기
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
798 질문 전체 보기
Dead battery needing manually charged
Does anyone know how to charge a dead lithium battery with another battery as I have a iPod that has a severely undervolting problem and I need to manually put charge into it
Any known methods
Any help will be greatly appreciated
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The only method would be to wire positive to positive and negative to negative of both batteries. In theory 2 working batteries should balance their power until it gets even, but if you have one dead battery it may not work. However, unless you know for sure the dead battery is not internally shorted or deteriorated, I would avoid playing with lithium batteries, as they have the bad habit to catch fire when things go wrong.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for the advise
Il avoid doing it and buy a new one
Thanks! :D
댓글 달기
귀하의 답변을 추가하세요
HelloMacOS 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 33
