주요 콘텐츠로 건너뛰기
Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
20002 질문 전체 보기
audio on my MacBook stoped working
The audio on my macbook suddenly stopped working. When I click on the audio adjuster, it won't even let me change the level (the little circle is white now, not blue).
But when I plug in headphones or an external speaker, everything works fine. I can once again adjust the audio and get sound
There was a red light eminating from the audio out jack for a while
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
The red light means your digital audio out has switched on. You can insert a plastic toothpick in the hole and try and switch it off. The switch should be at the 3 o'clock position and go towards the 6 o'clock position. Some people also have had luck inserting their headphone jack and pulling out a few times. Another recent report was that inserting the headphone jack and turning it in the hole helped.
해당 답변은 도움이 되었습니까?
점수 6
댓글 달기
귀하의 답변을 추가하세요
pascal 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 331
