주요 콘텐츠로 건너뛰기
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
My SP has the screen white but plays games fine.
After turning on the GBA, the screen goes blank but the sounds play. Games load and button input with the game works fine, so the game appears to run fine. The only problem is the video output.
I swapped the screen for another one that I know works perfectly and the GBA shows the same issue no matter the screen, so it must be a damaged connector or something with the motherboard.
Where should I start?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi Nan!
I know that if the ribbon cable is not all in the connector, it can show the same issue you got now. Is it deep enough in the connector, for like 100% sure and locked? If yes, then I'm afraid you should replace the motherboard... Could be the connector or any other micro component which failed.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Hello koppie007.
Yes, before making this thread I swapped the screen and tested it in another SP that I know works, and I confirmed it wasn't an issue related to the screen. It must be something with the motherboard.
Thing is, I don't know where could I start to troubleshoot my issue. Maybe the connector works but it doesn't get the video signals right?
Thanks!
@anana Yes, I think the connector is done for, as everything else is actually working. Could also be a capacitor.. It's hardy to say to be honest :(.
댓글 달기
답변을 추가하세요
NaN 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 165
