주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
465 질문 전체 보기
SSD not recognized by MacOS Recovery
Hello
My OWC SSD is not recognized by MacOS Recovery Disk Utility in my 2013 Macbook Air.
I carried out the Mac OS High Sierra update and successfully used the SSD for about a year. Then I think I did something wrong during a factory reset, and the drive is no longer recognized. Is there some way to send it out to OWC to get it reconditioned?
Otherwise I will see whether this procedure works.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Thank you mayer and jack labred for your responses. I will update when I can get to it this week!
댓글 달기
답변 2개
선택된 답변
Boot the machine up from an external source Mac and see if you can run Disk Utilities from it. If you don't have one, phone a friend with a Mac and use Target Mode.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Success!!! I finally have mac os running off my newer OWC drive in my 2013 MBA.
It took a lot of tries. The trick was to get High Sierra or later an external USB. This allowed me to "see" the OWC drive in recovery mode and apply "reinstall mac os" to it.
Next time I want to wipe the OWC I will have to go through this mess again :/
댓글 달기
I think it's better to start with: boot your Mac while holding [Command + R].
Select Disk Utility and see if you can mount it this way.
Open Disk Utility, click View in the menu bar, and select Show all devices. You should now see your SSD drive listed above Macintosh HD and Macintosh HD Data volumes
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dave Dei 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 31
전체 시간: 570
