주요 콘텐츠로 건너뛰기
The 5-door Explorer and its companion the Mercury Mountaineer were redesigned entirely for the 2002 model year, gaining a similar appearance to its big brother, the Ford Expedition.
A.C Not working in front of the vehicle
Just getting hot air. Even after i move the switch to the A.C Possition is still blowing hot air
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
You might be better served finding and joining Ford Explorer forums where similar owners share answers.
댓글 달기
답변 2개
가장 유용한 답변
There are a few basic points that you have to check if getting hot air from AC.
  1. Check the AC mode. Change it to the cooling mode.
  2. Clean dust and slit from the fin of the AC. Use water and soap foam to clean it.
  3. Check the temperature sensor.
  4. Confirm you have cooling gas in your AC and the compressor is working.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I paid $500 to replace the compressor, only to find out it was just a loose connector on the condenser fan…
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Edilberto Sibrian 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 6
지난 30일: 13
전체 시간: 462
