주요 콘텐츠로 건너뛰기
Released June 2017, the iPad Pro 10.5" replaces the 2016 iPad Pro 9.7".
145 질문 전체 보기
No display after screen replacement
My iPad had a cracked screen with severe LCD damage where all could be seen is lots of colored lines. I got a Apple Original screen to replace it and when I installed the new screen and hit the power button all I get is the backlight (no image just a black dim screen) for about 3-5 seconds and then it turns off. I transferred my home button to the new screen and it works fine as I am able to put the device in dfu mode with it and force restart. when plugged into my Mac it doesn't show up in finder until I put it in recovery mode or dfu mode. when restoring it gives me an error 4013. when I put the damaged display back on, it restores without a problem and works as it should other than the damaged LCD. I don't see why the new screen isn't working. Any help is appreciated!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
You have purchased a faulty aftermarket screen. Return it for a refund and purchase one from a reputable supplier.
Apple does not sell replacement screens. Unless it was pulled from another iPad it will be aftermarket.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Yep I figured that which is unfortunate. It was pulled from another iPad but it must have been faulty. I got my return label and am getting a full refund and I’ll buy another from a different source. I will see if the issue persists when I get another screen which It shouldn’t as I will most likely buy it from ifixit. I was trying to avoid the $200 for a new screen but if that’s what it needs that’s what I’ll do.
댓글 달기
if you change the LCD without disconnecting the battery then might be light-related issues check it correctly.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I made sure I had a pick under the battery connector the whole repair. I am returning the screen because I think the unit I got is defective
댓글 달기
귀하의 답변을 추가하세요
Hayden Freeland 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 12
전체 시간: 381
