주요 콘텐츠로 건너뛰기
Model A1288 / 8, 16, or 32 GB capacity
451 질문 전체 보기
Why won't my new LCD backlight and digitizer work?
I bought a used ipod touch 2nd gen off of ebay.
It said the digitizer didn't work, also found out the LCD screen backlight was out, but you can see it if your under light. I replaced the LCD screen and digitizer and it didn't fix the problem. What can i do to fix this? Any answers would help...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
williamcasey80, this was my answer to a very similar problem right here." if the icon etc. are visible, that means your backlight is not functioning. The backlight is part of the LCD, and the backlight circuit is on the logic board. I would go ahead and start with the cheaper of the solution, and that is by replacing the LCD. Of course, make sure that you restored the iPod and have done any of the updates and also reset the settings. From the Home screen->Settings->General->Reset All Settings. If none of that works, you are looking at having to either replace the logic board, or replace the coil on it. The replacement of the coil is very tedious, very small and needs some special skills. Check on here for a picture of the coil." different model but possibly same issue.
Hope this helps, good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
williamcasey80 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 957
