1994 jimmy won't start, getting fuel
1994 jimmy won't start, checked plugs,pump, filter, relay????
Update (04/19/2022)
4.3. 6cyl. 4wd. Auto. No turbo
좋은 질문 입니까?
좋은 질문 입니까?
Heidi Edgmon your Code 5-4 is the code for Fuel Pump Circuit Voltage Low which would explain your voltage being at 2V. I would start by trying to direct to wire the pump to a 12V line to see if it runs. After that I suggest you check the wiring for a possible bad connector/broken cable/poor ground.
Take a look on here for the fuel pump wiring test. Let us know what you find out.
해당 답변은 도움이 되었습니까?
Ok let you know
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 77
댓글 2개
Heidi Edgmon what engine size is this? Do you have spark? does the engine crank over? did this just happen all off a sudden ro anything that preceded this? What and how did you check things out?
oldturkey03 의
Yes spark, yes on crank, ...no slowly ... Replaced fuel pump, checked relay... Spray starter into intake, start them die...
Diagnostic read CODE 5-4, fuel pump ...less than 2 volts???
Bench tested old pump ...worked...???
Heidi Edgmon 의
