주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
How to fix stuck bootlooping
how to fix iPhone 6 s plus boot looping I have this iPhone 6s plus that has a good battery and is stuck boot looping I was using it and it just froze and then I turned it off and then once I did this it just rebooted and now has been like this for a couple of hrs how do I fix this problem also the phone does this when unpluged
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Put the phone into recovery mode and do an update with iTunes or 3uTools. Let us know if you receive an error.
해당 답변은 도움이 되었습니까?
점수 1
댓글 9개:
i tried to put the phone i recovery mode by pressing and holding the home button and off button but it just shut off and then when i let go it still just went back on am i doing it right?
@keith_themuscovyduck Keep holding the home button and power button, the phone will eventually shut down and restart keep holding the buttons until recovery mode. If it will not go into recovery mode you could try DFU mode but you might have to do a restore instead of update.
ok thanks i got it in recovery mode
@imicrosoldering
i updated and its still bootlooping
@keith_themuscovyduck If it updated without any errors you will need to rule out a parts issue. Replace the battery first.
댓글 4개 더보기
댓글 달기
귀하의 답변을 추가하세요
keith_themuscovyduck 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 7
전체 시간: 120
