주요 콘텐츠로 건너뛰기
Chevrolet/쉐보레가 제조한 승용차 및 트럭 수리 설명서 및 지원.
1367 질문 전체 보기
How come my chevy doesn't hold a charge
I have a 2006 trailblazer ls with a vortex 4200 engine. The battery is new and although it can be charged, it doesn't hold the charge for less than 24 hours. I am thinking it's a short somewhere but don't know how to locate it
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi,
With the engine off and key removed from the ignition, disconnect the negative (-ve) battery cable from the battery and then connect an Ammeter (function found in a DMM- digital multimeter) between the -ve battery cable and the -ve battery terminal i.e. the meter is in series connection with the earth connection to the battery i.e. chassis earth > -ve battery cable > meter lead in - meter lead out > battery terminal.
Set the meter to measure DC Amps 10A scale. The normal current measurement is between 50-75mA (milli Amps). This is the amount that is normally needed to maintain the clock, radio settings, any security systems (if fitted) etc
If you measure more more than this amount, start pulling the fuses one by one and then check when the reading drops to the normal amount.
Knowing which fuse it is will tell you what circuit is draining the battery. The fuse allocation chart either in the fuse box lid or the owner manual tells you what circuits the fuse supplies. Here's a link that also shows what circuits the fuses supply.
Be sure to replace the fuse you have removed, before removing the next one so as to not confuse which fuse belongs where as they may have different ratings.
You need to check both fuse boxes, underhood and passenger compartment if it doesn't show up if only checking the one or the other fuse box first.
Start with the lower rated fuses first i.e. 10A, 15A, 20A as some of the higher rated fuses i.e. 40A, 50A etc, probably feed the lower rated ones. This is so that if there is a fault in a circuit it only blows a minor fuse and not a major one that could affect other circuits which are working normally.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi Dwayne,
Have you checked that you don't have anything plugged in pulling power while the car is off? I bought a backup camera for my car and I left it plugged in for a few days (without driving) and it drew enough power from my battery that it died. The easy fix is that I only plug it in while I'm using the camera. Even when these sorts of things are off (cameras and whatnot) they can still draw a good amount of power.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dwayne Campbell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 45
