Screen falls apart, lines appear after a short while
Hello!
I have a newer model Samsung tv which works perfectly when I turn it on but after a while the screen starts to "fall apart" and horizontal and vertical lines start to appear.
When I turn off the tv and turn it on directly after, it does the same thing right away, but if I let it cool down for a while, when I turn it on again, all is fine for a short while again.
Depending on ambient temperature this can happen from anywhere between 4-5 minutes to almost immediately.
The TV has a Samsung oneconnect box, but there should not be an issue with that since when unplugged, the screen still goes bad after a while just like when it is plugged.
Some videos of the issue:
https://drive.google.com/drive/folders/1...
Any idea where, on which board should I start looking for the issue?
Any help is appreciated.
Thanks,
Soma
좋은 질문 입니까?
댓글 2개
What do you mean by "falling apart"?
guardian10 의
@guardian10 Thanks for your reply!
I have attached a link to google Drive with some videos showing the issue.
The screen gradually starts to get dimmer and dimmer while vertical lines appear which follows the brighter image on the screen.
For example if there is a white logo on a darker screen that moves from left to right, these lines that go from the top of the screen to the bottom of the screen will follow the logo.
Sorry if unclear, a bit difficult to describe it. Hope you can open the attached video I made.
Thanks!
Soma 의
