주요 콘텐츠로 건너뛰기
비디오 출력이 있는 컴퓨터 또는 기타 기기의 스크린 (또는 모니터) 수리 안내서.
505 질문 전체 보기
Can I swap the motherboard of the same monitor with similar one?
Okay so I have a sceptre c355w3440un 35 inch LED curved monitor that doesn't boot at all or have a standby light. I thought it was the power board and replaced it, but it still won't boot, so I want to buy the main board to replace it. The problem is that the board I found is on the same monitor(same name and looks the same) looks slightly different than mine. I have a JRY-W9CUHD-AV1 and this other monitor has a JRY-W9CUHD-NV2 they look very similar, would these two be interchangeable?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
They look very similar but they are in fact quite different. The connectors are all different and many components change type and positions. I don't recommend that you use that other board. I recommend that you purchase the exact motherboard the monitor had installed as it's the only way to be sure of it's compatibility. Ebay or ali express may have it available. Good luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Fay bo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 18
전체 시간: 515
