이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
kristjan666 first you want to check your charger. Make sure that it works. then check your cable and see if that is working properly. After that you are looking at replacing the batteries and repairing the charger port. I suggest you check videos like this to at least get you into the speaker.
oldturkey03 의
