How do I fix the seat belt ribbon?
Seat belt is not being pulled back in
좋은 질문 입니까?
If its not pulling in at all I would think it needs to be replaced. The mechanism is a complex little part that can even have a small charge that fires with the air bag to tighten the belt a little.
When you pull the belt all they way out dose it make the typical seat belt noise? Then its just all out sitting there with zero tension?
I had a belt that would retract slow or only 90% of the way; I washed the belt in hot water to make it more flexible, that helped a lot.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 8
30일 전: 21
전체 시간: 104
