주요 콘텐츠로 건너뛰기
다양한 주방용품 수리 안내서 및 지원.
Clean the limescale on the kettle
We have a disc electric kettle at work, we use it for more than a year, there was a scale on the disc, it became unpleasant to drink tea. Just rinse and rinse does not help, what can you clean? I would be glad to hear your suggestions!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Fill pot to minimum level, add a teaspoon of cream of tartar. Stir contents or swirl the pot a couple of time to mix the powder with the water. Boil water until it shuts off. Pour out contents. Rinse pot several times.
댓글 달기
답변 3개
선택된 해법
Buy some citric acid power and put a table spoon to the kettle with water. Boil the kettle and most of the calcium should break off and dissolve. After the kettle has cooled rinse with water and wipe clean. If it has not removed all the limescale just repeat. Citric acid is food safe and natural.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
Run vinegar through it (boil it) a time or three this will remove the mineral deposits repeat until you see its all good. The vinegar is acidic and especially heated eats the basic lime away.
이 답변이 도움이 되었나요?
점수 5
댓글 6개:
Agreed. Vinegar makes an excellent calcium/lime deposit remover. OP make sure you let the vinegar sit on the scale build-up so that it has time to work!
Brandon is right you can heat it before end of day then leave it soak overnight (off, for safety)
You could even use some lemon juice or something as well
Anything mildly acidic,. Yes. Coke for example LOL.
This also works on shower heads and so on. As Brandon pionted out soaking helps so does agitation. Heat speeds up chemical reactions. A bit of scrubbing once softened helps too.
댓글 1개 더보기
댓글 달기
baking soda and boil it 2 times and then do it the 3rd time with plain hot water then tip it out and put fresh water in it and its ready to use again.do that every 3rd week
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Baking soda is wonderful stuff for removing/controlling odors, will cut grease quite well and lots of other things but its a base, not an acid so this will work to control odors, yes.
댓글 달기
답변을 추가하세요
Lia Hughes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 11
지난 7일: 39
지난 30일: 131
전체 시간: 1,756
