Restarts every 3 minutes because of thermalmonitord
Iphone se 2
https://zhidao.baidu.com/question/336459...
Thanks to Chris Stables answer, successfully fixed
Repair process
좋은 질문 입니까?
Iphone se 2
Repair process
좋은 질문 입니까?
The thermalmonitord sensor your log is referring to is mic 1 which is located on the Lightning Connector Assembly and will restart every few minutes if the CPU cannot communicate with the sensor. . Make sure you purchase one from a reputable supplier and not somewhere like eBay. Here’s the repair guide.
해당 답변은 도움이 되었습니까?
Thanks for your answer, I try to fix.
I tried this solution using the replacement part sold by ifixit, and it was a lot of fun, but I still have the same issue. The panic logs show the same cause. Any advice on possible next steps? --Thank you @imicrosoldering
24 시간 전: 3
7일 전: 9
30일 전: 28
전체 시간: 2,601
댓글 6개
Hello. What this Chinese guy did in this video is real? he tested the flex cable without entirely removing and installing it first. How did he do that? I am an amateur. I bought a damaged iPhone SE to change the piece with an original one , but I noticed that if I had bought a new piece it would have a sticky tape to fix inside the vessel of the phone and if I do just removing from the other iPhone SE , I wouldn't have the tape , can I do it with another thing or without any tape at all? THXS
Jesse henrique 의
@imicrosoldering could answer for me please?
Jesse henrique 의
@jessehenrique You can use some double sided tape if the charging port assembly has none left after removal.
Chris Stables 의
Thank you! I am confused about the 71 part of the guide iPhone SE 2020 Lightning 커넥터 어셈블리 교체 I really didn't get what to do. It is confusing the converter antenna cable and the small adhesive patch. I would like to know if I can open my iPhone with the conventional way (a suction) and heat because three months before this problem , my iPhone had a battery replacement in a AASP and they do something to make it dust and waterproof again , what is that and how can I open it properly knowing this?
Jesse henrique 의
@imicrosoldering
Jesse henrique 의
댓글 1개 더보기
