주요 콘텐츠로 건너뛰기
Released September 2015, the JBL Xtreme is a portable, Bluetooth speaker that is also splash proof.
102 질문 전체 보기
Will charge 3 connect to Extreme
Will a JBL Extreme 2 or 3 blue tooth to my Charge 3 ? Is Extreme Connect or Connect +, I believe Charge 3 uses connect?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
As your Fitbit watch has bluetooth capabilities, this should not be an issue. If you follow these steps you should be able to pair the two:
  • After ensuring your speaker is properly charged, activate the pairing mode on your bluetooth speaker by powering on the device, and pressing the bluetooth icon button. (A blue light will start flashing and you should hear an audible noise indicating your speaker has gone into pairing mode).
  • While your speaker is waiting to pair, enter the app settings on your watch and select bluetooth and then + audio device
  • Your watch will return a list of available devices, so just be sure to select your bluetooth speaker. I would recommend being close, but you don't necessarily need to be right on the device unless one or the other may be experiencing signal issues.
  • When the pairing is complete a checkmark should appear. Be sure the volume isn't set too loud unless you're entering beast mode :P.
Note Should this not work please power off both devices, and start the procedure again. I hope this helps and if not please return and we will assist further to get you all set!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Dan DiStefano 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 147
