주요 콘텐츠로 건너뛰기
2022년 2월 25일에 출시된 Valve에서 만든 휴대용 게임기, LCD 디스플레이가 장착된 Steam Deck의 수리, 분해 및 문제해결 정보입니다. 모델 번호 1010으로 식별됩니다.
ZIF connector locking tab broken - Any fixes?
So in an attempt to replace the screen on a damaged deck I somehow managed to knock off the locking tab for the display zif connector on the motherboard. The connector still sits in the socket but the display does not work. I assume the issue here is the missing locking tab causing issues with connection, is there any fix for this or is the motherboard now a paperweight?
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
So the short and skinny of it is that there are ways to fix a broken ZIF Connector. However, they're not particularly easy to accomplish. There is a similar question that was posted here that has a solution and gives you some options for repair. My suggestion is replacing the port itself. There is a video guide that shows you how to replace the port here, but it requires micro soldering skills.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Rosie Turner 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 26
전체 시간: 1,287
