주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
405 질문 전체 보기
Mac boots to white screen, nothing else works.
I have a Late 2011 MBP that just boots to a blank white screen. I've tried the usual SMC and NVRAM reset, and the problem still persists. It also cannot boot into target disk mode, nor recovery mode.
I don't know if it's the GPU or something else, I'm completely lost.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
You'll first need to do a full SMC reset. Pop off the bottom cover and disconnect the battery, now with nothing connected press and hold the power button for a good 15 secs. they lets the logic board charge to be discharged. Now plug the battery back in and the MagSafe. This time when you start the system press the T key to enter into Target Disk Mode. Do you see the FireWire/Thunderbolt icons on the screen? If you do they you proved the discreet GPU has failed and SMC was stuck in a latched state which is why you couldn't get past the reset.
I don't see the FireWire icon on the screen, it's still showing a blank white screen
댓글 달기
답변 1개
선택된 답변
I found out the issue:
The SSD. Somehow the SSD I had in it was causing the issue somehow
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Average Old MBP User 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 52
