주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
iPhone X fell and has charging issues
So as soon as my phone is plugged in it displays the charging animation however when I disconnect the charger the screen goes blank immediately without showing the battery low animation. Intermittently it comes on but is stuck in a bootloop.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
I have found that bootlooping issues that occur only when plugged in may be caused by a battery issue (disconnected or connection issue).
Has the battery ever been replaced before? For example, I had a phone (iPhone Xs) with a previous battery replacement brought to me for a similar complaint after the customer had dropped it. When plugged in, the phone would either display the charging symbol, or would bootloop. In this case, a battery replacement solved this issue.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Try cleaning out the charging port and if that doesn’t fix it replace the charging port
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Micah Jatau 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 42
