samsung blocking parts replacement? No network after part replacemen
My S20+ port got moisture problem, so i bought a replacement charging port on ebay. here is with i found
- disconnecting and connecting OG charging port fix the moisture problems but randomly happen again in between 1 to 3 week
- I get no network if i boot with replacement charging port.
- If i boot up with OG charging port, then change it to replacement charging port. everything works Till i restart the phone
why is this happening? is samsung blocking third party parts?
Update (06/03/2022)
forgot to say when i meant no network, it mean a a circle with a line cross it
but yeah, i meant the whole USB-C Charging Port. my phone is the Taiwan model(i am in UK currently), the G9860, i made sure the replacement part is for the G9860(its printed on the board).
If its incompatible parts that is causing the network problem, it should just not work at all, they fact the changing part works mean its not a hardware problem right? i actually went to a third party repair shop with the same result.
oh, i just noticed the above pic is the exactly same as my replacement part(all the model number matches)
but my OG part is slightly different compare to the above pic, highlighted the red circle from picture of my OG part
좋은 질문 입니까?
댓글 3개
Can you link where you got the replacement part from?
Jacob Mehnert 의
I cant find it on ebay again, but its the same as the one posted by Alisha below
Sion12 C 의
I've had a similar issue on my Galaxy s20 5g...
No network when i replaced the charger port/board.
I'll strip it down again to see what the odel is.. annoying to say the least
Ian
Ian Pidgeon 의
