주요 콘텐츠로 건너뛰기
Repair guides and support for the first generation of Sony's RX100 high-end compact camera with a 20.2 MP sensor. The Sony Cyber-shot DSC-RX100 was released in June 2012.
How to fix viewfinder not staying down?
Camera fell leaving a dent on the top near the flash, as a result the viewfinder will not stay down. This results in having to use the viewfinder as opposed to the back screen when shooting.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Similar problem here. I once popped out the viewfinder and now it won't retract/kept locked in down position.
Did you find any solution for that problem?
댓글 달기
답변 1개
가장 유용한 답변
As a quick fix, you can use a rubber band to keep the viewfinder in. This covers slightly the back screen, but you should be able to still see enough.
I found a small independent repair shop. They opened the camera, and replaced the spring in the viewfinder. They told me it was rusty, due to excessive use in wet/damp conditions (could be well true, as I used the camera also during all sorts of hiking trips). It costs me only 60$, much less than the original Sony repair shop.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Dan Hernandez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 220
