주요 콘텐츠로 건너뛰기
Model A1311 / Mid 2010 / 3.06 및 3.2 GHz Core i3 or 3.6 GHz Core i5 프로세서
342 질문 전체 보기
No power chime/no power/no fan/no noise when button press
When I try and turn on my mid 2010 iMac 21.5 inch, nothing happens. When I plug it in, the first diagnostic green LED turns on, and when you press the power button it immediately turns off and nothing happens. Literally nothing. Nothing at all. No chime, no other lights, no fan spin, no hard drive spin, nothing. I have ordered a completely new replacement board and put everything back together. The same problem happens. Could this be the power supply? I ordered one off of eBay and it should arrive on friday, the 10th. What else could this be as I've eliminated the possibility of it being the logic board as I replaced it already.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
It could be your power supply, but it could be the power button, check both.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
It could also be your RAM
댓글 달기
귀하의 답변을 추가하세요
Joshua Glenn White 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 9
전체 시간: 39
