주요 콘텐츠로 건너뛰기
Stylus for the iPad Pro (3rd Generation) featuring gesture controls and magnetic attachment and charging. Launched November 2018. Model A2051.
18 질문 전체 보기
How can I remove the tip that’s snapped off on the inside?
I dropped my Apple Pencil a few days ago and the tip snapped off. I ordered some new tips and I tried to screw one in with no luck. I looked it up and a piece of the broken tip might still be inside the Pencil. How can I get this out?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
가장 유용한 답변
Hi
First of all I must say I am sorry to here of this unfortunate event but not to worry as we can fix this!
There is the bottom part of this Tip still inside
Here how to get it out!
My advise would be to get a sewing needle and start scraping away a little of the plastic (on the bit stuck inside)to create a little slope in the bit that’s stuck inside just until you can turn it out
Hopefully this helps but if it doesn’t comment on my answer and il help you get back on with drawing with your Apple Pencil!
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
@oldturkey03
Thanks for letting me know
I had no idea!
Thanks again:-)
Il give it my best shot!
Hey I got mine out by using the broken tip. I slid it over the metallic transducer, till it meshed with the broken bit, then unscrewed it (anti-clockwise looking at the pointy end) with some light pressure. Your mileage may vary depending on the shape of the break though. Good luck everyone!
댓글 달기
I didn’t know this was a thing till it happened to me! So I took a pin and made a small hole in the stuck hub of the tip till the pin was and then started rotating the stuck part counter-clockwise till it came up. The gave the pen a shake and it popped out. Thank you for the solution!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Omg this is what has happened to me and why I’m here. I’m so glad I’m not the only one this has happened to. I’m giving this advice a try now. I hope it works.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Anja 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 34
30일 전: 131
전체 시간: 6,013
