주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kia unveiled its newly redesigned Sportage at the Frankfurt Auto Show in September 2015, with plans to bring it to market as a 2016 model.
Horn continues to go off after horn fuse pulled in Kia Sportage 2017
I woke up to my Kia Sportage 2017 horn blaring. Hitting unlock on the keyfob would stop the horn for ~0.5 seconds with each press. I located the fuse compartments but was unable to pull the fuse without tools. I tried starting the car, and within 30 seconds the horn stopped. I then removed the 15A horn fuse in the engine compartment - it was not blown.
About 20 minutes later, the horn started blaring again. I started the car again and within a minute the horn stopped blaring. I have since removed the B/Alarm relay and the batter from the keyfob. The horn has not blared again, although it has only been 15 minutes since. Is this a relay failure mode? How would the horn keep blaring after the horn fuse was pulled?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
your horn is also sent power from your security system. That is where the problem is.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Matt Burris 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 710
