주요 콘텐츠로 건너뛰기
The Ryobi P202 part of the Ryobi One+ series. This model is an 18-volt cordless 1/2 inch drill, and is bright green and grey in color. It has a built in level gauge and a two gear ratio switch on the top of the drill, along with a direction switch, magnetic tray, and drill bit clip.
11 질문 전체 보기
Trying to repair my Ryobi BCL14181H battery charger
I have a BCL14181H battery charger (Ryobi) that does not charge. No blown parts. I am having trouble identifying components. Does anyone know the component number for U5? It is a 20 pin SMD chip. Also there are some components that look like an SMD resistor but appear to be jumpers. they are labeled RJ1, etc. Component U4 has what looks like T8L05 stamped on it. Anyone have an idea what it is?
Update (06/12/22)
I tried it with a battery that is at 16.5 volts and it doesn't work. I can put the battery in a known good charger and it charges up.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
I am trying to identify two components on the board. the first one is labeled U4 and actually looks like a transister in a TO type package. the other one is labeled U5 and is a 20 pin package. Does anyone have any idea what the identifying numbers are for these?
댓글 달기
답변 1개
If your battery is totally dead the charger may not recognize it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Conrad Gauthier 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 304
