주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
NTC error after FaceID Repair
Hello,
I had Face ID failure on my IPhone X phone. So I decided to fix it. I did all the steps in full and pass the module to a new flex. When doing the test with my I2C tester it passes all the tests (leds turn on...) but the NTC fails. I don't know if it's the fault of the new flex I bought or what. Attached photo of the tester and the module.
Thank you very much.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
my too
Do you have any solution?
@vanthea - Sorry there is no solution other than letting Apple repair it as they can update the security credentials of the part.
댓글 달기
답변 1개
Sorry FaceID and NFC security elements are part of the circuit so while you replaced the part and your tester is telling you the part is working physically, its not going to allow the replacement circuit to work as the security keys are not correct (as they are new). Only Apple has the tool to reprogram the phone for the new key.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Im not replacing it. Im doing a dot projector repair.
@pwnorz - See if clearing the FaceID and reloading a fresh image fixes it. The stored image maybe off. Otherwise there maybe security linkage between that is messing you up.
댓글 달기
답변을 추가하세요
Vladimir 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 24
전체 시간: 1,942
