주요 콘텐츠로 건너뛰기
모델 A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 질문 전체 보기
J9001 something inside blocks my cable connector
Imac genius, refer to my two photos, do i need buy a top magnifier to check what inside J9001 is blocking my cable connector?
I see 12 metals from above. Which pin(s) block me? What is doable to enable cable connector insertion 100% into board connector?
(Out of careless mistake, my screen fell down desktop last week. The connector is partially broken)
Update (06/13/2022)
This is my existing insertion situation.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
You need a new connector at its physically damaged. There is no means to make this work as the socket pins are a fork type. While you might be able to insert the cable end it won't make electrical contact with the mating connections.
As much as I would love to offer you a magical answer to make this work I just can't (nor anyone else can either).
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thx Dan. Soldering on such very narrow space is like launch a rocket to the moon to me... Cannot shake hands, must have eagle eyesight... I will try buying some used tools to fix it asap. Thx your insights and selfless sharing. U give me a hope.
댓글 달기
Hi Dan,
I fixed it.
After purchasing the original logic board connector from taobao, I realise that a quick fix is to remove the front cover, and erect the 6 pins upright 90 degree to the floor.
The board connector & cable connector at J9001 eventually fits to each other firmly.
My solder skill too poor. I am too poor to buy a professional hot wind gun. The above solution is quite happy to me.
Thanks Dan. I posted my previous wrong thoughts and my final outcome. Just use a mini 1-shape screwdriver to erect the pins...fixed it...the pins were tilted to screen side (as opposed to electric power back side ) due to screen drop onto desktop.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
pmp calvin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 127
