주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Important power lines and their resistances?
Hello. I have an iPhone 6S logic board with a small current leakage (20 mA). Could somebody please tell me what are the important power lines on this phone and what are their expected resistances, so that I can measure the resistances of my board' s power lines and compare them to the theoretical values?
Update (06/16/2022)
iPhone 6S, water damaged. Hasn' t been dropped. Doesn' t power on. The resistance of the PP_VCC_MAIN is around 400 ohms, which I think is normal. I need to know which other power lines I should measure to find what' s the problem.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 5개
How do you know it has a 20mA current leak? When you measured PP_VCC_MAIN did you have the multimeter in diode mode with red probe on ground?
I connected a DC power supply at 4V to the battery FPC, and the current draw was 0.02A
@cavemahn What is the diode reading on “PP_VCC_MAIN” and “PP_BATT_VCC” Red probe on ground.
PP_VCC_MAIN is 450, and PP_BATT is 660. Shouldn't they be smaller?
@cavemahn PP_VCC_MAIN “0.420” PP_VCC_BATT “0.414” You said it draws 20mA is that before prompt to boot? If so what does it draw when prompted to boot?
댓글 달기
답변 2개
가장 유용한 답변
vcc_main is the main power rail but there are numerous power rails. can you tell use more about the phone, any liquid damage, has it been dropped. does it power on ?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
A water damaged phone does not work because the water has created a short in the circuit. That short creates a higher current draw which damages components and creates a bigger short usually with some carbon burn. Measuring power bus resistance will likely get you nowhere.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Sus Amogus 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 125
