주요 콘텐츠로 건너뛰기
다양한 종류의 시계 수리 안내서 및 지원.
How to keep battery powered clock from slowing down
my battery clock runs slow even with new batteries installed. is there a fix for this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
This is a fix that is more complex than my clock; it does give me an idea for upgrading to a better time piece. Thank you.
댓글 달기
답변 2개
선택된 해법
While altering the crystals timing can improve your clocks time keeping, it may not offer enough as the battery runs down.
Another way of having a clock that syncs up with WWVB which is a radio signal many clocks use to hold their time. Another source is the Internet time server which you can access over the internet. Some clocks today can leverage it via WiFi or even a hardwired Ethernet connection, as an example my weather station does this.
Sadly, these options will likely require a new clock to leverage.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
@ortheo There are ways to calibrate a quartz watch movement, but it depends on what exact movement is used in that watch.
Most watches lose or gain seconds (sometimes several a day), even high end Rolex mechanical and Patek Philipes! Mechanical watches usually requires a watchmaker with highly sensitive equipment to get just right. And watches are also subject to interference from static, like magnetism, etc.
If you can, either by finding your manual or opening the back cover, find the exact movement part number and Google fex (Seagull 2551 quartz movement calibration)
(That movement is the current most used Chinese movement.)
I have a SEIKO Solar which I’ve had for a year or so, and it loses about 1-2 seconds bimonthly (which is how often I have to adjust it because of the calendar).
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Ted Rockwell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 11
지난 30일: 157
전체 시간: 4,048
