주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for top and front loading Whirlpool brand washers.
Spin cycle sometimes won't start
Whirlpool top load washer. Gets to spin cycle and doesn't start but I can hear motor. If I turn off wash cycle and turn back on the spin cycle kicks in and completes.
I thought clutch was issue, replaced and still happening.
Any thoughts? Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi,
What is the model number of the washer?
@jayeff Model # Lxr7244jq3
댓글 달기
답변 1개
선택된 해법
@M. Kornhoff
Sorry for the delay.
I was trying to locate the tech sheet for the model (Whirlpool 4313896 aka LIT4313896) to hopefully see the wiring diagram for the washer to check if the cycle timer was the problem by knowing what timer contacts are used for the spin cycle. It may be a worn cam or a worn or dirty contact in the timer.
Unfortunately timers are not reparable, they have to be replaced. (part #WP8572976 I think - maybe confirm if number printed on timer)
Given the cost of a timer, (search online for the part number), you could try liberally spraying a specialist electrical/electronic contact cleaner (example only, there are others) into the timer to see if this clears the problem. Disconnect the power before doing this and allow sufficient time to dry before reconnecting the power to the machine.
Do not open the timer as you will have cams and contacts everywhere - usually there are about 12 cams and 20+ contacts in a timer. Hopefully there may be some holes in the casing that you can use. Also do not use standard WD40 as it leaves residues.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
M. Kornhoff 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 14
전체 시간: 1,296
