주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
iPhone 6s not turning on
I accidently dropped my iPhone 6s in boiling water for about 3 seconds and took it out
immediately, the iPhone warned me the tempraturewas too high so i put it near the window to dry, when, it accidently silpped out of my hand and fell out of the window on grass, now it doesent turn on or even charge?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi Addicted2Tech,
Unfortunately, there aren't a quick fix for water / liquid damage. It will require some fair disassembly and inspection.
There are several LCIs (Liquid Contact Indicators), one in the charge port and more inside the housing.
You should never try to charge a phone that has been subjected to liquids, that will only quicken the corrosion.
What I would start with, is to open the phone up and inspect it closely.
Further, I would disassemble it, at least taking out the logic board, and I would probably disassemble the charging port as well.
Using the highest percentage isopropyl alcohol you can get (at least 99%), I would pour enough into a dish (or something) and place the logic board into there, fully covering it. Isopropyl alcohol aids in dissipating the water from the board.
While in the iso, I would use a soft brush (preferably ESD safe, but a soft toothbrush will work), and brush over both sides of the logic board. NOTE! Be careful as some components are fairly easy to damage.
Once this is done, leave it to dry in a warm, but not toasting place. The longer it dries off the better, but iso evaporates a lot faster than water. You can do the same to the charge assembly, so dissipate the water.
Here is a guide on how to access and take out the logic board from an iPhone 6S. Be sure to keep the screws correctly organized, as you DO NOT want to mix up a long and a short screw (millimeters count, ever heard of Long Screw Damage?). May I suggest an iFixit magnetic screw organizer?
Now, once the parts have been through this process, and you've inspected it for damage as best you can, reassemble the phone and test it out for functionality. (Unfortunately, some liquid damage does require board level work to be repaired.)
Magnetic Project Mat 이미지
상품
$19.95
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
it could be to do with it being liquid damaged is why it doesnt turn on
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Addicted2Tech 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 48
